B
Buick84gn
Guest
Folks,
Finally decided to fix a leaking up pipe, which came to be when I changed the turbo last summer. Wasn't a huge leak, at the manifold connection. I've tried every position on this thing. Still leaking. Now, the nuts and studs on the NEW turbo from GM are "seized" and would most likely snap if I try this again. Also the bolt closest to the intake on the turbo is nearly impossible to tighten. But the leak is at the manifold, anyway. I'm getting really fed up with this, what am I doing wrong. Which joint do you guys tighten first? The manifold or the turbo?. Also, in case it's the pipe that is messed up, who sells the "ATR STAINLESS" pipe?
Many thanks in advance.
Ken
Ken
