Up Pipe - Same as Turbo Regals??
TR Custom Parts
Mark Hueffman - Owner
I have a potential customer who wants to buy an up pipe for his TTA. Are they the same dimensions as the Turbo Regals up pipe??:confused:
Buttt... the chrome ones that are bent like 90 degrees.. will rub on his hood liner. The stock up-pipe will have one leg longer than the other bringing it closer to the IC.
So if the up-pipe has un-equal length's.. it will work.
HTH
The legs need to be stock length (as the stock pipe) or it will rub the hood insulation. I got a stainless steel one that has unequal length legs but the shorter of the two is still slightly longer compared to the stock pipe hence it rubs against the hood insulation. I had it powder coated silver and it ended up with a dull spot on top after rubbing the hood insulation :-( Just had the stock pipe powder coated and will install that one instead .....
