OOops let me be more SPECIFIC
:redface: Im sorry guys
i need to be more specific here are the mods that have been done so far : what do you think i should do next alky or headers and up pipe ...............I also dont have sticky tires :biggrin:
TRW Forger 30 over pistons
Ported and Polished Heads
Ported and Polished Intake
009 Injectors
Billet Adjustable Fuel Pressure Regulator
Hot Wire Kit
Walboro 340 Fuel Pump
206/206 Webber Cam
Billet double roller timing chain
New Comp Cam valve springs
Upgraded Turbo (flows similar to a TA49)
Custom Lee Thompson 3" Down pipe
3" Stainless ATR Single Shot exhaust
Turbonetics Deltagate
Turbonetics In-Car Adjustable Boost Regulator
Big Mouth Cold Air Intake
87 Mass Air Flow Sensor
87 ECM
Turbotweak Chip
additional Red Armstrong Chip
Turbo Pre-Luber
2 Huge oil coolers(trans/engine) with electric fans(fans arent hooked up)
Autometer Oil Pressure and Boost Pressure Gauges
PTE Oil Filter Relocator
Polyeurethane Trans and Engine(both sides) mounts
PTS Aluminum Transmission pan(additional 2.5 quarts)
PTS Shift Kit
PTS Transmission Pressure Regulator
Many A/N fittings and Push Lock hose
Scan Master
SOOoooo ............What do you guys think i should do next
