Ok went out to the track to play with this NX set up . Car was run on 28x11.50 MT ET slicks , which i belive kill the car off the line but any way Car was sprayed entire track 100 shot , using Lowtimming chip 19 deg 1st 18 deg other gears . Fuel was C 16 . The total boost was 22-23 with the spray . The other things my car has are in my sig . First pass was 12.28@109.44 w/ 1.76 60 ft. @2nd 13.55@109.24 w/2.45 I screwed up that one . 3rd pass 12.22@109.25 w/ 1.72 4th. 12.36@ 107.14 w/ 1.79 60 the last pass i jetted up to the 150 shot and the car ran out of the spray 12.71@106 1.76 60 . At this point i put in my Reds 100 chip with 26 deg timming and ran a 12.47@107.91 / 1.85 same boost about 22-23 . I did nine more passes with the Reds chip with 25-27psi boost the two best times were 12.03@110.81 w/1.69 and 12.01@110.89 w/1.69 the mphs were mostly 110-111. I put this down for anyone curious . I dont think the 28 tire is good on my car . My Car may be on the heavy side i dont know. Full weight fronts , The susp is set up for street not all out drag , The springs in front are 5660s with 36mm sway and ive got two amps in the trunk , power seat . The cell had 10 gallons of fuel the stock tank maybe 5 . Anyway next time ill try the 150 shot. I did 15 passes and drove home so thats good .
