(updated) Definately something for everybody!!!
BLACK MAGIC RACING
formerly turbo_canuck
86/87 parts:
-Stock heater core- $60
-Stock crossover pipe(2) -$ 35 each
-stock intercooler - $80
-turbo heat shield - $30- pending
-3.42 richmond gears - $90
-stock intercooler shroud - $20
-stock inlet bells (2) - $5 each
-stock up pipe - $20
-stock wastegate actuator $15
-turbo bracket $15
-clear parking lenses - $15
-stock posi rear - $800
-stock turbo (core) - $90
-stock front sway bar - $40
-4 stock t-type wheels w/ caps - $275
-Front bumper, no lights oe bezels, fair shape $75
-pair gn lower door panels- $60
-complete engine harness - $250
-4 GN wheels w/ new caps- $300
-2 85 gn wheels with broken center rings (good for slicks) - $100
-stock gn valve covers - $60
-stock downpipe (2) $20 each
-stock fuel pressure regulators (3) $20 each
-2 stock ECM- $75 each
-2 stock turbo cranks - $300 each
-Blower motor- $50
-Flexplates (2) - $35 ea.
-Throttle body and plenum, no arm, spring or iac- $ 125
-Cruise control unit- $ 40
-EGR valve and solenoid- $ 50
-Stock shifter- $ 30
-Right side air dam- $ 25
-Stock intake-shaved .030 - $80
-water pump pulley (2)- $30 each
-Stock fuel sending unit- $30
-Stock 87 Grill- $90
PERFORMANCE PARTS:
-ATR stainless headers for stock style heads- $700- pending
-Champion GN1 Aluminum heads, w/gn1 valve covers, scorpion roller rockers,head stud kit-$1400
-Ported intake W/ 70mm Precision plenum, RJC power plate, 70mm Accufab throttle body, Accufab regulator on modified fuel rail,
EGR block off plate, .- $550- pending
-Pair of 1026 fel-pro head gaskets- $80
-March underdrive pulley kit w/intercooler fan- $120
-B+M line lock- new- $60
-New heated 02 sensor kit- $80
-204/214 speed pro hyd. cam - $75
-.030 speed pro forged pistons - $200
-ECM modded for low impedance injectors- $145- pending
-Extender Xtreme chip for 95's- $90
-95 lb Delphi injectors- $300
-4.10 richmond gears - $125
-B+M torquemaster torque- 2800-3200 stall, th350,th400- $200
-2" to 3" reducer hose-blue- $20
-2.5" to 3" reducer hose-blue- $20
-3" by 3" long intercooler hose- $10
-2.5" by 3" long IC hose- lt. blue-$10
-High pressure adjustable wastegate actuator te series - $60- Pending
-High pressure wastegate actuator-ta series- $60
-Various t-bolt clamps- $10 each
-RJC power steering pump pulley- $50 new!- pending
-RJC water pump pulley- $60- pending
-RJC crank pulley- $120- pending
-RJC Idler pulley- $50- pending
-Lokar trans mount dipstick + tube- $50
-alternator fan- $10
-BRF core transmission- $250
-Moroso trick rear springs w/ airbags- $145
-Pair of mint redone GTA rears- $ 225
-Weld 15x8 prostars, 4.5"backspace, drilled for screws- $200- pending
-Pair of 8.5" vectors, centers painted black, holes drilled for screws- $175
-Pair of 8.5" vectors, good shape, $250
-4 polished center lines- 2 15x7,3.5" bs, radial tires, 2 15x8.5, 4.5" bs, 26x10 slicks.- $800
-Weber Billett roller cam, 218-212, 511,503 lift. 113 lsa.- $275
-Weld 10x15, 5.5 BS w/ 28x 10.5 mt et drags, - $500
-Auto meter 5" tach, w/ shift light, - $90
-New Heavy duty GN 2004r driveshaft, w/yoke, new spicer joints.- $350
-3.5" stub downpipe, 4" long, build your own DP, internal gate. - $200
-Custom oil pickup tube for stage 2 blocks- $95
-Wiseco forged pistons for 4.1, clearanced for stroker- $ make offer
-Rollmaster billet-crank style timing set, 20-25 runs- $75
-Extended 14 bolt oil pan, deepened 1", $125
84/85 PARTS:
-complete intake - $90
-turbo/ throttle body assy. (core) - $80
-engine accessory bracket - $25
-braided down pipe - $20
INTERIOR:
-Grey steering wheel- $45 (rough shape)
-Green Steering wheel- $80
-grey dash pad - $80
-rear quarter window trim - $15 pr.
-3rd brake light - $5 each
-t-top wide front trim - $10
CAR AUDIO:
-Alpine CDM-7861 flip face cd player- $150
-Alpine CDA7863 flip face cd player- $ 190
-MTX thunder4122 2 channel amp- $ 100
-Memphis mono amp 16pr1kd- $ 250
FRESH LONGBLOCK ---10-15 RUNS:
10/10 stock turbo crank
billet center mains
RJC girdle
stock checked + magged turbo rods w/ ARP bolts
.030 forged speed pro pistons, plasma moly rings
comp cams 212-212 hydraulic roller cam + lifters, roller cam button
rollmaster timing set
comp hi-tec pushrods
hi-volume front cover
RJC head gasket kit
Fully race ported iron heads
manley severe duty stainless valves 1.77/1.50
t+d shaft mount roller rockers
comp "beehive" springs, retainers, and locks
cost me over $5000 u.s to build, sell for $4000,(or $4500 with complete intake above) only 10-15 runs on it!!! Ran 10.53 on soft 1.70 60' foot times @ 136mph
Prices do not include shipping, but MAY be a bit negotiable :biggrin:
are these the ones for the bumper? if so can i get pics.
Turbo
How bad is the turbo ( housing bad or wheel damage )? Does it come with intake and exhaust housings. Thanks
DCVING, these are the ones for the bumper, they're probly about a 6 out of 10, a couple of hairline cracks that aren't really visible unless you're close up, hence the $15 price tag :tongue:
Turbo6Chicago, the wheels are in good shape, great for a driver, maybe a 7 or 8 out of 10. I'd like to sell all 4 at once, unless someone else wants the other two at the same time.
G-bodyguy, line lock is brand new in the box
Bat, I actually have 2 cores, both very rebuildable, with both housings. no wheel damage.
TURBOTWIN2, stock intercooler and shroud came off a 85k mile car, not bad shape at all
Woody1969, will work on getting you some pics this afternoon, as well as all others. thanks!
Shroud for intercooler
I'm looking for the shroud only. $20/shipped to 78023? Let me know. Thanks.
turbo_canuck
Clean your pm's your full. And does 20 bucks shipped sound ok to you.,
turbo_canuck said:
I could go $30 shipped, it's gonna be a good sized box, and texas is a LOOOOONG way from montreal... :eek:
Call it $25/shipped and you got a deal. Thanks.
Are these sold yet
DCVING, these are not mint, you know that, right? they're about a 6 out of 10, if you're ok with that, $20 will cover it. +the 3% paypal fee.
blownbuick, i never got the mail.
TURBOTWIN2, if you cover the 3% paypal fee, it's yours. :(
speed11, i'm waiting for the money order right now. i'll let you know if it falls through.
/QUOTE]
Uh, I was gonna use a money order. Will you take one from the U.S. Postal Service? Tell you what, since you're such a swell guy, I'll throw in another couple bucks on the deal. It ain't much, but it is 8% extra. $27 total. Send me your info. Thanks.
I'll take the "clear parking lenses - $15"
shipping will be to Selinsgrove, Pa. 17870 and let me know what your paypal email address is with a total... Thanks... :)
PM box is full
Your pm box is full. Hit my regular email about the turbo. Will you go paypal for that price.
