(updated) Definately something for everybody!!!
turbo_canuck
I will still take them lenses. Pm me with your paypal address. Thanks Jon
TURBOTWIN2 said:
turbo_canuck said:
TURBOTWIN2, if you cover the 3% paypal fee, it's yours. :(
/QUOTE]
Uh, I was gonna use a money order. Will you take one from the U.S. Postal Service? Tell you what, since you're such a swell guy, I'll throw in another couple bucks on the deal. It ain't much, but it is 8% extra. $27 total. Send me your info. Thanks.
Payment sent!
$550 for EGR Blockoff plate?????????? Tell me I am missing something here? The rest of your prices are fair but $550 for a $15 plate?? I must be reading this wrong??
-Ported intake W/ 70mm Precision plenum, RJC power plate, 70mm Accufab throttle body, Accufab regulator on modified fuel rail,
EGR block off plate, .- $550- pending
Take another look.
86/87 parts:
-Stock heater core- $60
-Stock crossover pipe(2) -$ 35 each
-stock intercooler - $80
-turbo heat shield - $25
-3.42 richmond gears - $90
-stock intercooler shroud - $20
-stock inlet bells (2) - $5 each
-stock up pipe - $20
-stock wastegate actuator $15
-turbo bracket $15
-clear parking lenses - $15
-stock posi rear - $800
-stock turbo (core) - $90
-stock front sway bar - $40
-4 stock t-type wheels w/ caps - $275
-Front bumper, no lights oe bezels, fair shape $75
-pair gn lower door panels- $60
-complete engine harness - $250
-4 GN wheels w/ new caps- $300- sold
-2 85 gn wheels with broken center rings (good for slicks) - $100
-stock gn valve covers - $60
-stock downpipe (2) $20 each
-stock fuel pressure regulators (3) $20 each
-2 stock ECM- $75 each
-2 stock turbo cranks - $300 each
-Blower motor- $50
-Flexplates (2) - $35 ea.
-Throttle body and plenum, no arm, spring or iac- $ 125
-Cruise control unit- $ 40- sold
-EGR valve and solenoid- $ 50- sold
-Stock shifter- $ 30- sold
-Right side air dam- $ 25
-Stock intake-shaved .030 - $80
-water pump pulley (2)- $30 each
-Stock fuel sending unit- $30
-Stock 87 Grill- $90
PERFORMANCE PARTS:
-ATR stainless headers for stock style heads- $700- sold
-Champion GN1 Aluminum heads, w/gn1 valve covers, scorpion roller rockers,head stud kit-$1400
EGR block off plate, .- $550- sold
-Pair of 1026 fel-pro head gaskets- $80
-March underdrive pulley kit w/intercooler fan- $120
-B+M line lock- new- $60
-New heated 02 sensor kit- $80
-204/214 speed pro hyd. cam - $75
-.030 speed pro forged pistons - $200
-ECM modded for low impedance injectors- $145- sold
-Extender Xtreme chip for 95's- $90
-95 lb Delphi injectors- $300-sold
-4.10 richmond gears - $125
-B+M torquemaster torque- 2800-3200 stall, th350,th400- $200
-2" to 3" reducer hose-blue- $20
-2.5" to 3" reducer hose-blue- $20
-3" by 3" long intercooler hose- $10
-2.5" by 3" long IC hose- lt. blue-$10
-High pressure adjustable wastegate actuator te series - $60- sold
-High pressure wastegate actuator-ta series- $60
-standard pressure adjustable wastegate actuator (2)- $45 each
-Various t-bolt clamps- $10 each
-RJC power steering pump pulley- $50 new!- sold
-RJC water pump pulley- $60- sold
-RJC crank pulley- $120- sold
-RJC Idler pulley- $50- sold
-Lokar trans mount dipstick + tube- $50
-alternator fan- $10
-BRF core transmission- $250
-Moroso trick rear springs w/ airbags- $145
-Pair of mint redone GTA rears- $ 225
-Weld 15x8 prostars, 4.5"backspace, drilled for screws- $200- sold
-Pair of 8.5" vectors, centers painted black, holes drilled for screws- $175
-Pair of 8.5" vectors, good shape, $250
-4 polished center lines- 2 15x7,3.5" bs, radial tires, 2 15x8.5, 4.5" bs, 26x10 slicks.- $800
-Weber Billett roller cam, 218-212, 511,503 lift. 113 lsa.- $275
-Weld 10x15, 5.5 BS w/ 28x 10.5 mt et drags, - $500
-Auto meter 5" tach, w/ shift light, - $90
-New Heavy duty GN 2004r driveshaft, w/yoke, new spicer joints.- $350
-3.5" stub downpipe, 4" long, build your own DP, internal gate. - $200
-Custom oil pickup tube for stage 2 blocks- $95
-Wiseco forged pistons for 4.1, clearanced for stroker- $ make offer
-Rollmaster billet-crank style timing set, 20-25 runs- $75
-Extended 14 bolt oil pan, deepened 1", $125
Car Parts
Can you shoot me pics of the wheels and perhaps a shipping costs to 21046. If the wheels are nice I will take them and you can subtract the cost of the covers. I have 4 new ones just waiting for some nice wheels.
TIA
Roger
TURBOTWIN2, no sign of it yet, but i didn't go to the p.o. today.
rhunt, which wheels? and what does TIA mean? :confused: :p
86/87 parts:
-Stock crossover pipe -$ 35
-turbo bracket $15
-Blower motor- $50
-Throttle body and plenum, no arm, spring or iac- $ 95
PERFORMANCE PARTS:
-Custom oil pickup tube for stage 2 blocks- $85
-Extended 14 bolt baffled oil pan, deepened 1", $125
