87 WE2
- Jun 28, 2002
GM timing set (complete), low miles, minimal ware
PCV
Turbo Oil feed
Turbo oil return
Turbo oil return brass nut
Vac Pod stock
Oil cooler lines
Power steering pump with pulley
Good motor mount
Heavy duty IC hose (turbo to IC)
Stock fuel press reg
Stock injectors
Trans cooler line shield bolts to pass side head
Trans inspection covers (2) bottom one has one mounting tab broken
GN bumper impact strip very nice 8 out of 10
AC line flex cover
Starter heat shield
(2) Delco 02 sensors
Non delco EGR
T stat housing
Stock T stat
Under hood relay for ac box
Tripple chrome plated stock oil fill tube with cap
Ported exhaust housing for TA-60 size wheel
Trans wiring clip for side of trans
Door escution
Seat belt trim
Fuel door lisence plate holder
2.5” exhaust clamp
2.25” exhaust band clamp, new
Exhaust elbow to downpipe donut gasket
Fender power antenna nut and sleeve
2 stock size oil filter adapters
IGN cylinder with key
Trans cooler line
Nylon platic inserts for license plate bracket screws 4 new
Headliner trip clip 1
2” heavy duty T clamp
Trunk catch with hardware
ECM good for core
2 cruise control boxes
Stock turbo, ported comp housing Garret 63. Exhaust with inlarged wastegate hole..
Stock turbo, port matched comp housing & inlet bell. Garret 63. exhaust with in larged waste gate hole professionally machined. Very minimal play, working when removed, no smoke. Turbo only, no actuator or elbow.
You will need an oversize puck in your elbow or downpipe, or an RJC plate to reduce it back to stock size wastegate hole. $150
84/85 BQ transmission $250 picked up $250 delivered within 50 miles of 19014. (I will not ship & no the motor is not for sale) *Open to offers
Parts without pics but I can get some:
AC lines, driver condition
19k miles trans pan with bolts
2 steel brake drums, painted with silver vht 1500 deg paint
Stock rear swaybar with hardware
Stock lower control arms
Tank straps, painted flat black & cusions
Lines above gas tank, in great shape.
B piller trim pair gray
Headliner trim above windsheild gray, driver condition
Set of oil cooler lines
***FREE PICKED UP****
GN rear bumper with rust in inside, paint bubbles from rust on outside. driver/race car condition (pick up only).
Could be cut down to export style mounts to lighten up a race car.
Rear bumper support, steel (pick up only)
Front bumper support, steel (pick up only)
Parts for sale :: IMG_3311.jpg picture by turbo231 - Photobucket
Parts for sale :: gnrearbumper.jpg picture by turbo231 - Photobucket
Parts for sale :: gnrearbumpertop.jpg picture by turbo231 - Photobucket
Parts for sale :: gnrearbumpertop2.jpg picture by turbo231 - Photobucket
PCV
Turbo Oil feed
Turbo oil return
Vac Pod stock
Oil cooler lines
Good motor mount
Stock injectors
AC line flex cover
Starter heat shield
Non delco EGR
T stat housing
Stock T stat
Door escution
Seat belt trim
2.5” exhaust clamp
Trans cooler line
ECM good for core
