& again...
I'll keep editing & updating...prices do NOT include shipping, but I'm reasonable on that. I will keep updating like this.
NEW as in NEW not nearly NEW: - all are real GM unless noted & for LC2's unless common others
- Coil packs, original Delco's (older original versions), $60 each - have 3
- Powermaster accumulator, $200
- A1-Cardone Powermaster accumulator (got from Kirban recently for $180), $160
- Cam sensor with drive assembly, $150
- Cam sprocket for timing chain, $30
- Front cover, $125
- Oil pump pickup tube with screen, $15
- Turbo heatshield, $55
- C68 electronic climate control blower control module (goes underhood near blower fan), $175
- Door strap screw covers, $10 each - have 4, maybe 6 - (silverish ones not the darker grey ones)
- Grey appliques for floor shift console trim plate around shifter, $40 each - have 2
- Set of 3 GN fender / trunk emblems, $135
- Pair of "Intercooled" emblems, $55
- Pair of "T-Type" fender emblems, $55
- Pair of "3.8 SFI TURBO" hood emblems, $55 - have 2 pairs
- "3.8 SFI TURBO" all-chrome trunk emblems, $70 each - have 2
- "Regal" quarter-panel emblems, $25 each - have 3
- Pair of 'T' fender emblems, $55
- 84-87 style turbo hood ornament, $190
- 6-way power seat switch assembly, $30
- LF, LR, & RF black wheel well opening moldings - only selling together, $475
- Rear differential housing cover, $20
- Pair of main wiring harness clips for up near HVAC module, $30
- MAF sensor-to-turbo flex hose, $40
Nice USED parts
- 87 shortblock (cam, pistons, rods, stock-sized crank, oil return line, main caps)...~60K miles, all pistons can move freely...stored in HVAC-controlled garage...may be able to be cleaned up as-is without rebuilding, but not positive...$800...not shipping, but will help with deliver within a 2-4 hours of Dallas...I'll throw in a grab bag of mixed parts, too, like a spare oil pan, etc.
- Complete sunroof module assembly (main pan, motor, glass, switch, headliner cover - fabric off)...worked when pulled out...same as the shortblock about not shipping...$250
- Pair of tubes for 15" slicks, $20
- Two 84-87 turbo hood ornaments...one is very nice ($100), one is nice but has a scratch on the chrome base ($60)
- C68 electronic climate control set up...main unit, vent control box from behind the dash, inside & outside temp sensors...was working when removed...great for spare to have around, $180
- Turbo instrument cluster for floor shift car includes black rear surround that it goes into as well as a nice front trim plate, the one that includes the little emblem (3.8 Litre)...that has the left A/C vent, park/turn light switch, and rear defogger switch, $150
- Purple / burgundy carpet from ACC...color matches perfect...in the car for a VERY limited time...saves weight, too, $100
- Intercooler brackets (traingle one, and 90-degree one), $40
- Stock upper plenum opened to 62mm, $40
- Almost new fuel rail, $125
- Two fuel pump hangers, $25 each
- Excellent shaped stock 200R4 oil pan with magnet, $35
- Nice Powermaster motor, $50
- Stock PCM, $50
- Left side grey Concert Sound door panel (lower portion only), $40
- One LS1 aluminum MAF, slight ding in one side's outer diameter, works fine, $30
