& again...
I'll keep editing & updating...prices do NOT include shipping unless noted, but I'm reasonable on that. I will keep updating like this.
NEW as in NEW not nearly NEW: - all are real GM unless noted & for LC2's unless common others
- Coil packs, original Delco's (older original versions), $60 each - have 4
- Cam sensor with drive assembly, $150
- Cam sprocket for timing chain, $30
- Front cover, $125
- Turbo heatshield, $55
- C68 electronic climate control blower control module (goes underhood near blower fan), $175
- Grey appliques for floor shift console trim plate around shifter, $40 each - have 2
- Set of 3 GN fender / trunk emblems, $135...for $150, I will include 2 nice and 1 decent original GN emblems, too, that you can retape and reuse!
- Pair of "Intercooled" emblems, $55
- Pair of "T-Type" fender emblems, $55
- Pair of "3.8 SFI TURBO" hood emblems, $55 - have 2 pairs
- "3.8 SFI TURBO" all-chrome trunk emblem, $70...I also found another one that has a not-really-noticeable crack for $30...basically, the emblem tried to snap in half when I mishandled it. When it goes on your trunk, you won't be able to notice it.
- "Regal" quarter-panel emblems, $25 each - have 3
- Pair of 'T' fender emblems, $55
- 84-87 style turbo hood ornament, $190
- 6-way power seat switch assembly, $30
- LF, LR, & RF black wheel well opening moldings - only selling together, $475 with free insured shipping in the lower 48 (no PO Boxes on this one)
- Rear differential housing cover, $20
- Pair of main wiring harness clips for up near HVAC module, $30
- MAF sensor-to-turbo flex hose, $40
Nice USED parts
- Complete sunroof module assembly (main pan, motor, glass, switch, headliner cover - fabric off)...worked when pulled out...not shipping...$250
- Pair of tubes for 15" slicks, $20
- Two 84-87 turbo hood ornaments...one is very nice ($100), one is nice but has a minor scratch on the chrome base ($60)
- C68 electronic climate control set up...main unit, vent control box from behind the dash, inside & outside temp sensors...was working when removed...great for spare to have around, $180
- Purple / burgundy carpet from ACC...color matches perfect...in the car for a VERY limited time...saves weight, too, $100
- Intercooler brackets (traingle one, and 90-degree one), $40
- Stock upper plenum opened to 62mm, $40
- Almost new fuel rail, $125
- Excellent shaped stock 200R4 oil pan with magnet, $35
- Nice Powermaster motor, $50
- Stock PCM (nice, out of an 86), $50
- Left side grey Concert Sound door panel (lower portion only), $40
- Grey GN / T-Type Regal steering wheel...just for a core for rebuilding as leather is torn...no horn trim ring or emblem, $25
