UPDATED: Lots of NOS, new, & used parts...
Happy Thanksgiving to all...
...also, I will be slow at email returns over the next few days.
& again...
I'll keep editing & updating...prices do NOT include shipping, but I'm reasonable on that. I will keep updating like this.
NEW as in NEW not nearly NEW: - all are real GM unless noted & for LC2's unless common others
- Coil packs, original Delco's (older original versions), $60 each - have 3
- Powermaster accumulator, $200
- A1-Cardone Powermaster accumulator (got from Kirban recently for $180), $160
- Cam sensor with drive assembly, $150
- Cam sprocket for timing chain, $30
- Front cover, $125
- Oil pump pickup tube with screen, $15
- Turbo heatshield, $55
- C68 electronic climate control blower control module (goes underhood near blower fan), $175
- Door strap screw covers, $10 each - have 4, maybe 6 - (silverish ones not the darker grey ones)
- Grey appliques for floor shift console trim plate around shifter, $40 each - have 2
- Set of 3 GN fender / trunk emblems, $135
- Pair of "Intercooled" emblems, $55
- Pair of "T-Type" fender emblems, $55
- Pair of "3.8 SFI TURBO" hood emblems, $55 - have 2 pairs
- "3.8 SFI TURBO" all-chrome trunk emblems, $70 each - have 2
- "Regal" quarter-panel emblems, $25 each - have 3
- Pair of 'T' fender emblems, $55
- 84-87 style turbo hood ornament, $190
- 6-way power seat switch assembly, $30
- LF, LR, & RF black wheel well opening moldings - only selling together, $475
- Rear differential housing cover, $20
- Pair of main wiring harness clips for up near HVAC module, $30
- MAF sensor-to-turbo flex hose, $40
Nice USED parts
- 87 shortblock (cam, pistons, rods, stock-sized crank, oil return line, main caps)...~60K miles, all pistons can move freely...stored in HVAC-controlled garage...may be able to be cleaned up as-is without rebuilding, but not positive...$800...not shipping, but will help with deliver within a 2-4 hours of Dallas...I'll throw in a grab bag of mixed parts, too, like a spare oil pan, etc.
- Complete sunroof module assembly (main pan, motor, glass, switch, headliner cover - fabric off)...worked when pulled out...same as the shortblock about not shipping...$250
- Pair of tubes for 15" slicks, $20
- Two 84-87 turbo hood ornaments...one is very nice ($100), one is nice but has a scratch on the chrome base ($60)
- C68 electronic climate control set up...main unit, vent control box from behind the dash, inside & outside temp sensors...was working when removed...great for spare to have around, $180
- Purple / burgundy carpet from ACC...color matches perfect...in the car for a VERY limited time...saves weight, too, $100
- Intercooler brackets (traingle one, and 90-degree one), $40
- Stock upper plenum opened to 62mm, $40
- Almost new fuel rail, $125
- Two fuel pump hangers, $25 each
- Excellent shaped stock 200R4 oil pan with magnet, $35
- Nice Powermaster motor, $50
- Stock PCM, $50
- Left side grey Concert Sound door panel (lower portion only), $40
& again...
- Coil packs, original Delco's (older original versions), $60 each - have 4
- Front cover, $125
- Set of 3 GN fender / trunk emblems, $135...for $150, I will include 2 nice and 1 decent original GN emblems, too, that you can retape and reuse!
- "3.8 SFI TURBO" all-chrome trunk emblem, $70
Nice USED parts
- Stock PCM, $50
& again...
- Front cover, $125
Nice USED parts
- Complete sunroof module assembly (main pan, motor, glass, switch, headliner cover - fabric off)...worked when pulled out...not shipping...$250
- Two 84-87 turbo hood ornaments...one is very nice ($100), one is nice but has a minor scratch on the chrome base ($60)
- Stock PCM (nice, out of an 86), $50
- Grey GN / T-Type Regal steering wheel...just for a core for rebuilding as leather is torn...no horn trim ring or emblem, $25
I think I've figured out how to add pics...let's try...
These are NEW GM stuff...
...and some more new GM stuff, other than the 3 GN emblems on the left of the picture as described in the later updates...
...and some more new GM stuff...
...and yet some more new GM stuff...
...now some used goodies...
...and more goodies, used...
...and more used stuff...
On this sunroof assembly, I am NOT shipping this. Sorry.
& again...
- Powermaster accumulator, $200 SALE PENDING
- Front cover, $125
Nice USED parts
I'll give 500.00 bux for all of it...and can pick most of it up my self this month ;)
Might need to add a bit...Ray, on the LS1 MAF, bad news, but good news. The one I had for you ends up being the stocker off my GTO. I'm keeping that. However, my friend has one and is sending it to me, for you, as he owes me some money / parts. Keep in touch as it'll be yours. Take care. Dave
