wondering what to expect,car went 11.00 at 121 on 23# it had je pistons steel center crank caps and arp bolts and studs champion alum heads scorpion rockers 212 flat tappet cam, 66 p trim ball bearing turbo cottons front mount intank dp 72 lb injectors,smc alky kit, fast computer, stock suspension NOW it has metco alum upper and lower rear control arms spohn sway bar ported heads comp roller cam 210/215 t&d shaft mount rockers 4in air intake cottons 3in ss exhaust, qa1 shocks all around just bought racetronix fuel pumps and all new lines, ported manifolds and now razor alky kit
