I've been pondering something lately... Could the high quantity of oil coming through the PCV be related to running open breathers? If you blocked in both the valve cover breather openings, the PCV would be trying to draw a vacuum on the crankcase, and the flow rate through the PCV would be low. With the open breathers the crankcase is at atmospheric pressure, and the higher the manifold vacuum you have the more flow you get through the PCV. That higher flow might be pulling a lot of oil with it.
I was thinking that if instead of open breathers, what if there was some device used that acted as a check valve. Whenever the crankcase is at some positive pressure (at WOT for example) the breather would let the excess pressure vent to the atmosphere. Under normal cruising or deceleration the breathers would close off, sealing the crankcase, and letting the PCV pull a good vacuum on it.
This would minimize the flow rate through the PCV at all times, and hopefully minimize the oil carryover into the intake. It would also do the best job of getting water and other contaminants out of the oil. Being able to actually pull a vacuum on the crankcase would do wonders on that score.
Only problem is... how to implement it? Only way I've thought of so far is a rubber flap type device, like a one way doggie door. Crankcase pressure builds up, flap opens, pressure released. Crankcase pressure goes down, flap returns to normal position, seals hole (which seals crankcase), and PCV can draw a good vacuum.
Or are there breathers already out there that act like this?
What do ya'll think about this?
John
