V-6 with third pulley.
dmarx
OK folks, what is the third pulley on the front of this engine? Is it an alternator mounting bracket, or perhaps an idler pulley?
Dan
dlmarx@bellsouth.net
Hard to say without knowing where the alternator will be. If there won't be alternator on the front, then I would say it's a tensioner pulley since the crank pull and water pump pulley are not adjustable.
It's a tension pulley for sure, But from what? I'm 100% that's not a GM part, I'd bet it was sourced or fabbed up when that engine is swapped into a different chassis. That part would never be used on any OEM setup especially with v belts, if it was a serpentine belt pulley... well that that's a different story.
Yep, not a factory part. Looks like and aftermarket AC set up that was put on it.
I emailed the owner and he doesn't remember what it is for. he has had the engine for 15 years. This engine is on ebay.
Dan
that engine is on ebay. i think its so you can use the toyota drives. not a factory part.
