vac lines and pcv in plenum spacer
just checking would there be any reason i couldn't drill and put the pcv and vacuum lines in my plenum spacer i want to put a new hood liner on but my vac block is tearing it
You sure could, but to make life easy i would delete the pcv at least that's the way i plan on doing it.
I would never delete the PCV, it helps control blow by, and crankcase pressures !
it also helps prevent oil leaks from gaskets and seals.
you need the correct PCV valve, and baffling, and can be used WITH vent hoses.
Yes you can. Do a search for push lock vacuum. There are some on those thread that have drill and taped the dog house for lines. I am going to do the same soon.
Bs, pcv does nothing for crankcase pressure while under boost, which is when crankcase pressure it at it's peak.
Oh i will, but it isn't even the 1st time i've done it...i did it on my daily driver T for years.
