Vac Lines
I just replaced all these on my car within the past 2 weeks. I'd also encourage you to use zip-ties to get the tightest seal....
Cruise Control Servo
Large port 9/32"
Small port 7/32"
Vacuum ball 7/32"
Washer Resevoir 8/32"
Washer Nozzles 7/32"
Charcoal Canister
To Tank 10/32"
Solenoid 8/32"
EGR to Solenoid 5/32"
Vacuum to EGR Solenoid/Check Valve for HVAC/Cruise 9/32"
Brake Booster 3/8" (9-9.5mm)
AFR 6.5/32"
Vacuum Block
3 ports 8/32"
1 port 6/32"
1 port 12/32"
PCV 12/32"
Wastegate Y-hose 8/32"
Total Lengths For Car
4mm = 122"
6mm = 147"
8mm = 46.5"
:D
