AN/GSC-52
- Dec 6, 2009
I have an 4" inlet turbo and a 1" intake spacer bar to accommodate. The issue is my hood liner (which was worn out already) has a hole in it. I picked up a NOS uber rare replacement but will not install until clearance issue is addressed.
Suggested solution for your consideration:
Modify the EGR block off plate to accept vacuum ports and eliminate the vacuum block.
****Your thoughts are appreciated***
