-86 GREEN Regal and 85 442 are both complete Pm with specific parts needs
-Regal doors(They have very little surface rust on under side) $150 picked up only
-Floor pan for bucket seat car $150 picked up only
-Rear quarter $150 each picked up only
-Rear frame rails $100 each
-Front frame rails $100 each
-Control arms(Front lower)$60
-Control arms(Front upper)$30
-Motor mounts(metal, frame mounts) $35
-Front fenders with GNX style louvers installed $150 for both
-Turbo crank(.010/.010) in nice condition $200
-Turbo crank(Std/Std but will need to be turned at most .010/.010) $250
-South side machine lower control arms(rear Lift bars)(In like New condition) $70
-Pro Comp Speedometer- make offer
-Pro Comp electric Water temp gauge- make offer
-Pro Comp electric oil pressure gauge- make offer
-Pro Comp fuel pressure gauge- make offer
-Pro Comp boost gauge- make offer
-Auto gauge 5 inch Tach with shift light- make offer
-Digital dash $200
-NEW Felpro gaskets(2 head gaskets 8723pt-1, 2 cork valve cover gaskets,2 Exhaust manifold gaskets) $35
-86-87 Alum Alt pulley $20
-84-85 Flex cooling fan $10
-Green Strip inj $100
-85 Power steering pump(For car with power master) $30
-Used Alum Rad $75 No engine or trans oil cooling)
-New in the box Griffin aluminum radiator(NO engine or trans oil cooling) $110
- trans cooler $20
-Nice set(drivers and passengers) of rewelded 84-85 exh manifolds $100
-Passenger side front bumper filler $50
-Header panel(GM) $150
-B body spindles $50 for pair
-85 Maroon bucket seats $200 good condition
-85 Gray bucket seats $200 good condition
-Maroon steering wheel in drivers condition, no center cap or ring $35
-Maroon shifter handle $25
-Blue shifter handle $25
-BQ transmission core(unknown condition) $100
-Crank window regulators $50 for both doors
-Dash vents(with nice chrome) $20 each
-Nice Gray card board and cloth inserts(under quarter windows) From 85 T-type $30 for both
-Gray dash pad with a small hole drilled at the lower right of the drivers seat(Its not even noticable) $75
-Visors good for cores(non mirror) $20 a set
-84-86 power seat track assembly $100
-Chrome marker light $35 each
-Passenger rear wheel well trim(needs to be repainted) $100
-Both tront head light bezels(need to be painted) $70 for both
-Rear center filler(The part that the rear license plate bracket attaches to) $30
-Pass remote mirror bracket(Just the bracket that attaches to the dash) $15
-NOS black plastic seat track cover for rear right side(GM part # 20023766) $20
-Frame in good condition $200
-heater box shield $10
-84-85 Shield to cover heat hoses $15
-bumperette rubber strips in good condition(used GM not after market) $20 each
-Stock factory lighter $8
-Stock Battery hold down $10
-85 gray bucket seats $250
- gray console $150
-Gray T handle for shifter $30 shipped
- Rebuilt 85 long block (10k miles) .030 Forged pistons, .010/010 crank $900
-Connecting Front Brace $25
-Front frame braces(underside) $25
- 86-87 MASS AIR FLOW SENSOR BRACKET $5
- 84 GN drivers side upper door panel good condition(but no chrome strips) $40
-Syclone (air/liquid) intercooler modified with 3 inch inlet and out let $125
-Plastic Brackets to mount front air dam $30 for 2(For both sides)
-Good hood shocks $10
-Stock turbo inlet bell $20
-009 injectors $150
-86-87 engine hoist bracket(on intake) $20
-Vac brake set up with New(Reman.) B body Master cylinder(master cylinder, vac asist and gbody pedal) $140
-New ARP Rod bolts 123-6002 $60
-New Felpro Valve cover gaskets(Perma Felpro) VS50156T $10
-GN driveshaft $50
BRF transmission $500
BQ transmission $250
87 gray cloth Limited front and rear seats $200
87 gray column (shift on column) $100
87 Split bench seat power seat track assembly $100
85 turbo Riviera std block $200
109 turbo block .060 over $100
87 Rebuilt 109 long block less then 1000 miles on it (Postons cam- 212 Int/206 Exh)(block .030 , .010/.010 crank) $1500
87 GN long block(around 100k) $800
Original GN fender extensions for car with spoiler
Maroon console $150
84 GN console $150
87 GN console $150
-84 Red upper door panels $80 minus chrome/gray strips $50
-Grey T-type upper door panels no chrome strips $50
-87 Maroon upper door panels $50
Drivers side Blackout head light bezel $40
Chrome head light bezels painted black $40 for both
Marker lights $40 each
Blackout wheel well moldings $60 each
Chrome(Regal) wheel well trim moldings $45 each
84-87 T-type header panel with hole filled $150
84-87 T-type GM header panel, has some small imperfections $125
84-87 Grand National GM header panel, has imperfections $125
Passenger remote mirror(needs paint) $60
87 GN seat belt set(10 pieces) $120
84 GN steering column $150
86 Blue steering column with tilt/cruise $150
Maroon steering column with tilt/cruise $150
87 GN grey column with tilt/cruise $150
87 grey column(shifter on the column) $100
84 Gold bucket seats $250 with rear seats $300
86 nice blue 86 442 bucket seats $150
Gray Monte SS seats $150
Maroon bucket seats need recovering $100
85-87 GN bucket seats need recovering $150
86-87 GN console $200
84-87 Consoles I am using for parts, e mail me with specific pieces
Shifter without T handle $25
shifter with blue T handle $50
85-87 Gray concert sound lower door panels $100
GN Dash Plaque $75
84-86 T-type dash plaque $50
86-87 Upper intake(dog house) $30
86-87 throttlebody complete(sensors,throttle lever, vac manifold) $100
86-87 bare throttlebody $40
86-87 Up pipe $25
86-87 Cruise control assembly $35
86-87 Water pump pulley $25
86-87 Main accessory bracket $70
86-87 Y bracket on back of Alt $35
86-87 Flat Y bracket on front of AC compressor $35
86-87 Intercooler brackets $25 each
86-87 Coil bracket ( The horse shoe shaped bracket) $30
86-87 Power steering res. bracket $20
86-87 Power steering pump $70
87 GN Electric fan $50
84 rad shroud $30
I have every piece for 84-87 GN engines(stock) E mail if you dont see it.
86-87 T-type wheels $100 each
87 locking t-tops $150
84-85 Non key locking t-tops $100
Astro roof complete assembly with wire harness, switch etc. $200 wont ship
Astroroof parts, I have the whole set up but the glass is scratched up, E mail with needs
Bigger then stock front sway bar $70
Fuel sender/fuel hanger(analog gauge) $80
87 BRF tranny $500
BQ tranny $250
Rebuilt BQ tranny $400
D-5 convert $50
Hot Air to Intercooled Conversion: Includes parts to convert from 84/85 to 86/87 Intercooled
setup. $1700
ENGINE PARTS:
AC compressor(84-85) $40
AC lines(84-85) $40
Adaptor(86-87 oil return to block, brass adapter,screws into block in front) $20
Adaptor(85 Turbo to intake adaptor) $40
Adaptor(Oil cooler adaptor with nut) $35
Air Cleaner scoop(86-87 Scoop for airbreather) $20
Air Cleaner assembly(86-87) $25
Air Cleanerassembly(84-85) $20
Alt.(86-87) $60
Alt.(84-85) $30
Balancer(Turbo harmonic balancer) $80
Battery cable guide(Small plastic guide that holds the posi bat cable to the lower front cover)
$20
Block(109 Block) $250
Cam position sensor just the lower part(no cap) $30
Cam position (sensor with cap) $65
Coil pack(84-85) $40
Coil pack(86-87) $25
Control module(84-85) $50
Connecting rods(2 dot) $40 a set of 6 or $10 for 1
Crossover pipe(84-85 Exhaust crossover pipe) $35
Dip stick and tube(86-87 dipstick and tube) $40
Dip stick and tube(84-85 dipstick and tube) $30
ECM(84-85 ECM) $40
EGR plastic cover $5
Elbow(84-87 Turbo elbow) $25
Flex plate(84-87 Turbo flex plate) $25
Fuel rail(84-85) $25
Fuel rail(86-87) $40
Heads(stock 8445 heads needing rebuild) $50 a set
Injector harness(84-85) $35
Intake manifold(86-87 Upper intake manifold)$35
Intake manifold(84-85 GN intake) $40
Intercooler $45
Intercooler brackets both for $40
MAF(84-85 MAF) $40
Main accessory bracket(86-87,the big alum. one) $70
Main accessory bracket(84-85) $40
Oil pan(Turbo oil pan) $40 each
Power steering pump(86-87) $70
Pulley(86-87 Water pump pulley) $25
Pulley(86-87 Alt pulley)$15
Rock arms+shafts(stock, complete set) $35
Throttlebody(84-85 Throttlebody with TPS,IAC motor,vacuum manifold) $40
Throttlebody(86-87 Throttlebody bare) $35
Throttle bracket(84-85 Throttle bracket) $20
Throttle cable(84-85 Throttle cable) $30
Timing cover $35
Valve covers (84-85) $30
Vapor cannister $10
Wire harness(84-85 engine wire harness) $150
INTERIOR:
I have every color interior parts except Green.
Arm Rests( grey, red, Maroon or blue arm rests) $20 for 2
Arm rest(Light sage green arm rests(these are the rare light green color)) $30 for both
Concert sound speaker covers(84 GN) $50
Console shifter plate(Plate on console that goes around the shifter)$25
Dash pad no cracks(grey or Maroon) $120
Door panels(85-87 GN lower door panels) $60
Door panels(85-87 T-type grey lower door panels) $40
Door panels(85-87 T-type Maroon lower door panels) $40
Door panels(85-87 T-type Blue lower door panels) $40
Gauge cluster(Analog) $100
Radio(Stock GN radio with cass, no EQ) $40
Sail panels(Grey interior panels around the quarter windows) for T-top car $40 for both
Sail panels(Grey interior panels around the quarter windows) for Hradtop car $40 for both
Seats(87 GN Front bucket seats need recovering) $150
Shifter $35(84-87 GN, needs T handle)
Steering wheel(good to have recovered) $40
Steering wheel(Tri shield GN horn center $40 no ring)
Steering wheel(T-type horn center $30 no ring)
Steering wheel(T horn center $30 no ring)
Surround(Gauge surround) $30
Surround(radio surround) $20
Third brake light(Grey, red, Maroon, or blue Third brake light)$20 Each
T-TOP trim around the t-tops on the inside of the car in, Maroon, grey and blue $25 for each
piece
Body Parts:
Blackout trim for front windshield $25 each piece or $60 for all 3
Blackout trim for rear window $20 each piece or $50 for all 3
Blackout trim around the door windows $20 each piece
Blackout Drip rails(hard top) $40 for both
Blackout(Trunk Lid blackout trim piece) $40
Blackout trim, T-top boot shaped trim that the T-tops lay on $60 for both
Bumper(GN Rear black bumper) $100
Bumper reinforcement(Alum. Front bumper reinforcement)$90
Bumper reinforcement(Alum. rear bumper reinforcement) $70
Front bumper shocks $25 for both
Rear bumper shocks $25 for both
Fenders(84-87 GN fenders(GM)) $100 each
Grill 87 GN Grill $200
Grill 87 Chrome grill painted black $125
Grill 86 T-type grill $50
Grill emblem(87 , says "Buick") $15
Hood(GN hood) $150-$250 (pick up only)
Hood Scoop(GN Hood scoop, cut from a metal GN hood) $50
Lock set(all 3 locks with key) $50
Mirror(Drivers mirror) $20
Mirror(Passenger Mirror,non remote)$20
Mirror(Passenger Mirror, Remote) $65
Quarter windows with blackout trim $100 for both sides
Tail lights with blackout trim $120
tail lights with chrome trim $80
Wheel well(Drivers Turbo plastic wheel well) $80 each
Wheel well(Passenger Turbo plastic wheel well) $100 each
Any other blackout piece e mail me I have them all
Misc:
Antenna base nut and spacer for Power antenna with black trim $10
Gas Tank(Turbo gas tank) $40 WON'T ship pick up only
Heater box(Complete heater box, For AC car) $100
Heater box shield $15
PowerMaster to firewall adaptor(bracket) $30
power trunk mechinism $20
Steering box(87 GN Power steering ) $35
Sway Bars(GN sway bars) $25 each
Transmission cross member $40
86/87 Tranny dip stick and tube $45
Transmission oil pan(Stock 200 4r tranny pan) $25
(2)Billet wheel adaptors 1/2 Make offer
84-85 T-type wheels $40 each or 4 for $120
84-85 GN wheels $100 each (no center caps) or 4 for $300
GNX Style 16 inch Wheels(Western wheels) $350
windshield wiper assembly $15
E mail
Fortune628@aol.com or PM me.(Best way to contact me.)
Cell number is 413 563 8819(I do NOT check voice mail on this number EVER.)
