Vacuum/boost line to f/p regulator
dennisL
I have an Accufab adjustable f/p regulator and just had to replace the rubber adapter from the plastic line to the barbed pipe on the regulator. It would blow off when the turbo came on! Since these things don't seal very well I was wondering if there is a better, more boost resistant way to connect the hard line (from vacuum block) to the f/p regulator. Any suggestions?
Most people just use vacuum hose and zip-ties. Ive never had one blow off using that method.
