John Larkin
Sublime Master of Turbology
- May 25, 2001
Ok, I can only hold 2psi. That's it. From what I'm told, the PM has like 1800psi braking pressure while vacuum has 900-1000psi. I'm also told that if you increase the piston size on a vacuum master cylinder, you lose braking pressure as well. So there are trade-offs. PM = unreliable due to parts that go south unexpectedly. Vacuum = less holding power usually.
Maximizing a system sounds great. Who radiuses shoes these days? I thought that went out with the asbestos scares. I've bled mine twice and still have a great pedal but low torque holding power. I have no idea how to make it better other than modifying the system to use a jumper valve to double the pressure to the rears. My converter stalls at 3200. Woody mentioned it could be a factor.
Hey, say it, spray it, whatever. Get your thoughts out here. This is good stuff.
