- May 28, 2001
Got my swap over complete. But the pedal seems harder than i figured it should be. What should i check for?
SignUp Now!Booster's bad if you have the hissing sound coming out of the booster. The seal is bad. If it was good then you might hear a slight hiss when you apply the brakes but only for a short time. Sorry Irv.I hear a pretty big vacuum leak where the master cylinder comes thru the firewall, can hear it from under the dash. What could that be?
Sorry to hear you had to do the job twice, but you should be able to enjoy drama free brakes now.Swapped to a new booster and all is well. Thanks all
