Vacuum Braking
Best bet and you'll have a lifetime warr is go to the parts store and get the booster and MC all as one assembly for less than 150 bucks and pull a vac brake pedal from a car in a Junkyard.
Pedal should be no more tha 10 bucks
Ah, the parts are from an 87 V6 naturally aspirated Buick Regal, I picked up a new MC and BB with a warranty for like $160 I think. You then get the pedal from Gbodyparts.com and for $200 you have a new system.
For $200 you can have a new hydraboost system, too and easily hold a ton of boost at the line without having to put it in neutral and rev it up to get some vacuum. It uses the stock pedal, too.
Is that all the lines too?
If you want new lines it might cost you $240 total with Tax.
The cost is pretty close to the core charge for a Powermaster :)
