80turbomonte
- Nov 3, 2004
have a serious vacuum leak going on 2 weeks now
it is a crb set-up with only three things needing vacuum
1.pvc
2.dist
3.brakes
this is a new motor 5 miles on it everything rebuilt including carb
i have 3 turbo carbs this is the third i have tried(kitted also)
tonight i resealed the turbo on carb side(gasket and o-ring)
didnt help with idle screw all the way out idles on 1150. i cant figure this thing out also on the road (might be related) runs great untill boost comes in then notta falls on its face boost go up rather quick to around 15 psi but does not pull hard at all. dont get any knock at all. starts falling off around 3000 rpms or so might be lean because of vacuum leak??that i cant find
1.pvc
2.dist
3.brakes
