Vacuum Lines On Swaps?
nboost
Just curious as to what you all did with all the little black boost/vacuum lines that run across the intake, when you did your swaps? I'd like to eliminate all that and just run a vacuum blockor something like that just to clean things up. Is this possible? Also, id imagine none of you are running the smog canister or anthing like that from the GN are you? I appreciate your help/input.
Pics would be nice too :)
i did a swap into a 75 firebird over this past winter,the only lines i used was for the fuel reg, pcv, boost gauge and vacum brakes. I bought a new vacum block with brake booster outlet from caspers.I blocked off everything else with plugs.I made a egr block off plate aswell.If you are not worried about emission caspers can build a custom harness for the motor and trans. I have one in my car now and it was the only way to go.
