I used a LT1 electric pump on my stock block for awhile. It only pulls about 1 inch of vacum, but that was enough to fix the oil leaks at WOT. The problems is that they cant take the heat and you'll melt the internals out of the pump if you run it continuously on the street. I had no problems after I set it to come on under boost.
