Hard to believe something as simple as valve cover gaskets can take days to find!
I first ordered a set from Summit - that ended up having no bolt holes in them! I had to make two seperate phone calls to their tech support line - over 30 minutes total trying to explain why these wouldn't fit on my 87 GN's stock valve covers.
Then off to AutoZone for a set of rubber Felpro's - whose holes didn't line up once the tabs were in place without some stretching (that oblonged the wholes) - plus would need some surgery on the insides.
Then off to NAPA, then Parts America...none of the cork or rubber gaskets would fit (without trimming and/or stretching)
Does anyone, besides GM, make a valve cover gasket that fit's the stock GN valve cover without an exacto knife? I looked at Felpros and Victors.
I know I replaced these several years ago without incident when I changed valve springs.
I'd prefer a steel shimmed rubber gaskets.
