Silver Fox
- Apr 17, 2003
I thought the driver's side would be easy, but I cannot get the two studs out of the plastic loom holding all the wires. I've done a search but can't find any solutions.
There appears to be two nuts, the one on the top (10mm), and another sandwiched between the upper and lower part of the plastic loom. I can't figure out the size of this lower nut - if I knew what size it was I may be able to force one of my thin "ignition style" wrenches in between the loom.
I loosened the top nut, and it loosened the entire stud. But, the loom doesn't give me enough slack to get the stud out of the valve cover.
Any tips on getting the two studs out of the the plastic loom off, without destroying it?
Thanks in advance.
Thanks in advance.
