sscamino
- Aug 3, 2010
Ive used cork ROL HiPer Blue VS749HP gasket,the big thing is in some places you have barely 1/8 of ruf cast surface area to seal the valve covers t. Try dry fitting and make sure the tabs go into the notches of the cover to hold them in place. Also make sure the gasket fits nice, snug and flat to the inside of the cover ,wipe of cover with a degreaser . Glue the gasket to the cover with either 3m super 77 spray adhesive or fel-pro yellow gasket adhesive and let dry.You can take them off and on numerous times.Another trick, if you have the heads off have your machine shop mill the top edge of the head(where the valve cover sits) flat to give a nice surface to seal to.I did this to stock and champion covers...no leaks.
