valve covers
turbobooster
are the 84/85 and 86/87 valve covers interchangable? can one fit the other and viseversa?
Pretty much but if you're going to use the 86-87 covers on an HA then you're better off than using the HA covers on an 86-87 engine. No breather on the pass side for the later engine so you can build up internal pressure easier.
im talking bout these
hello people; HIJACK I just saw those VC on another thread and they mention there thicker for a better seal. No leaks. Do you think that's true?
IBBY
gotcha yea they would be for my 85 and that is my concern about that clearance with the uppipe i might just pass them up
nothing wrong with them they r stock chrome covers just thought those were sweet looking might just spend that money on a 355 lb fuel pump instead
Have you seen pics of my motor? I have the tall valve covers with no issues
ive been looking for that pic all over the website lol i seen them a few weeks back but completely forgot where or who it was ... so it was u nice ! the minute i seen them i liked where can i see a pic of urs at ? maybe post up in here
i went out to look at my valve covers to compare the driver side breather hole to these custom black ones posted on here and the hole on the custom ones is not in the same location as the stock one the hole on the custom ones is more towards the firewall which makes the hole sit right under the intake tubing and right exactly where i have some plate with sensors and vacumm lines attached on top of the valve cover ....did u have this problem? can that plate with sensors and vacumm lines attached to it b relocated?
My filter/ breather hole is in the same spot as you describe. Yes that bracket can be moved. I don't use any of those sensors anymore.
y dont u use those sensors anymore ? wat did u do with the vacumm lines that run to that plate im talking bout?
