I recently came into possession of a comp cams 210/210 roller cam I which to put in my car.
Serial # T 7162-10 Spec Card# 18469210
Part # 69-000-8 CAMSHAFT, BV69 SPECIAL HYD ROLLER
Core C69-8A CAMSHAFT BLANK, BV69 BUICK EVEN FIRE DUC
Grind # BV69 3324S /3324S HR110 +2
DURATION @ .050 INTAKE 210 ROCKER ARM RATIO
VALVE ADJ INTAKE .000 DURATION @ .050 EXHAUST 210 INTAKE 1.55
VALVE ADJ EXHAUST .000 LOBE LIFT INTAKE .3170 EXHAUST 1.55
VALVE LIFT INTAKE .490 LOBE LIFT EXHAUST .3170
VALVE LIFT EXHAUST .490 LOBE SEPARATION 110.0
DURATION .006 INTAKE C/L 108.0
TAPPET LIFT INTAKE 260 CAM ADVANCE 2
TAPPET LIFT EXHAUST 260 HYDRAULIC Y
VALVE TIMING .050 OVERHEAD CAM N
VALVE OPEN INTAKE 3- JOURNAL DIAMETER STD 1.786
VALVE OPEN EXHAUST 37 RECOMMENDED VALVE SPRINGS
VALVE CLOSED INTAKE 33 DEPARTMENT P
VALVE CLOSED EXHAUST 7- SPC INSTR FOR CUSTOMER
What springs would be recommended with this cam? I was recommend by comp cams 26918 springs, 787 retainers, 601 locks and 853 lifters. From what I have seen on here; I would rather use the morel lifters.
My budget won't allow roller rockers at the moment; would I be better off with the TA HD rocker shafts or the rocker shafts supports?
I have going to have some minor porting done on the heads and probably have a machine shop give them a once over. The car is an average bolt on stock internal long block on alky with a 6262.
