- Feb 18, 2006
I'm working on a car with M & A heads. The motor will not go past 5100 rpm. The logs show nothing. Car pulls clean to 5000 then it breaks up. So I started to investigate the valve train.
Back when the car was sold the add said: Crane 212/206 Roller Cam, lifters, springs
So I yank of a valve cover and pull a valve spring. Start to do some measuring and found the install height is 1.890. The mystery spring is a single coil. I have not got over to the machine shop to measure spring tension but the installed height seems too high. Just doing some basic searching on the net I don't find much.
Any insight?
Rick
Any insight?
Rick
