What is too much?
Ive heard different #s mentioned as good, usually between 90-110 lbs. What is stock?
I just finished doing a bunch of porting work on my heads and then dropped them off to a machinist who I used to work under and have great respect for. I asked him to take care of them and do whatever he felt they needed. He gave them a performance valve job (3 angle valve job), got rid of the guide sleeves (I think they were copper) and put in screw-in type. These sleeves by the way were part of the problem that had me taking the engine apart in the first place. One had an exhaust valve stuck open. He also put in all new exhaust valves (as mine were pretty well worn), rusurfaced the heads (.010 came off), and new seals of course to fit the new type of guides.
Okay, back to the question. He set the spring pressure to 130, and felt that this would be good. I expect it would be good for topend, which is fine by me, only worry I would have is that it would be rough on the cam. He told me that some engines have the spring pressure at 500!
What do you guys think? I really respect his views as he has been doing this for 40-50 years, but would like some more input.
 I have heard of people running 130 (Precision turbo) sells springs right around there, but IMO, that is
