valve spring retainers
buickruss
If I were to lose a keeper from my stock GN heads, can I use a v8-455 or 350 set of valve spring retainers? Not sure if they are the same size
all GM keepers are the same, stop at any automotive machine shop and he will give you a few, if not I have some I'll gladly send you.
Are you talking about the retainers or the locks/keepers????
The retainers go on top of the springs
The locks/keepers go AROUND the valve stem to "lock or keep" the retainer and spring in place.
NO on the valve locks from a Buick 350 or 455 fitting a V6, the Buick V8 uses 11 degree locks, so its a no go.
Heres the difference between the Buick 455 and V6 locks/keepers
thank you for the info. I have done several GM more chevy and was unaware the 11 degree was used on the 455. My bad
Buickkruss I do have plenty of the correct keepers and retainers if needed for a Buick V6.
