8 87Turbo-TWE4 Member Joined May 9, 2008 Feb 12, 2012 #1 What are good springs above the stockers? Thought I would go ahead and take care of this.
W we4Mateo Double you eee what? Joined Apr 7, 2010 Feb 12, 2012 #2 I'm using the stock 75lb replacements from T/A with the cups but most use comp 980's.
S scojack_2001 Livin' Like A Refugee Joined May 24, 2001 Feb 12, 2012 #4 Comp 980s here, no problems at all.
Bescurred BOOSTED SHAMU v2.0 Joined Jun 10, 2001 Feb 12, 2012 #5 How many miles are on the car? I replaced mine at 170k and ended up wiping out the bottom end lol...
S scojack_2001 Livin' Like A Refugee Joined May 24, 2001 Feb 12, 2012 #6 Bescurred said: How many miles are on the car? I replaced mine at 170k and ended up wiping out the bottom end lol... Click to expand... Right now, about 126K. Probably had 105ish on it when they went it. They've been in there a while.
W we4Mateo Double you eee what? Joined Apr 7, 2010 Feb 13, 2012 #7 Bescurred said: How many miles are on the car? I replaced mine at 170k and ended up wiping out the bottom end lol... Click to expand... Are or were you using zddp?
8 87Turbo-TWE4 Member Joined May 9, 2008 Feb 22, 2012 #8 The odo says 28K but I believe it to be 128k (no documentation). Compression test showed fine. I seriously doubt it has had any zddp in it ever but I changed the oil using VR1 and a bottle of zddp.
8 87GN_70GS Active Member Joined May 28, 2001 Feb 22, 2012 #9 New stock replacements will work well for a stock setup. Sealed-Power VS-744 available at local parts stores.
