Yes it can be done, you can do one at a time. Note: you will need an air compressor, air line and fitting that screws into the spark plug hole. This is used to fill the cylinder with air and hold the valve in place while the spring, retainer and valve locks are removed and not holding the valve. I've done this lots of times on small block Chevys to replace valve guide seals. PM me if you need more specific info.
