Valves Hit Pistons!
1QWIK6
Torque wins
MY timing chain broke. The t/c tensioner bracket broke, snaping my chain(stock). Anyone else ever have this happen?
When I took my heads off all my valves were bent. I noticed the pistons (TRW) have sm marks in them from the valves.
Is this a problem? Hot spots later or nothing to worry about? :confused:
smooth the nicks out the best you can. should be ok any marks are going to heat faster if you are running big boost then pull them out
