The tach started getting flaky, then quit working all together. It is a VDO. I have a black wire, red wire, and white wire. Black is ground and red shows 13 volts. White only shows 2.5 volts. Is this how it should be or has the white wire gone bad? I think this happened once before and my mechanic spliced in a new white wire. I can't believe his wire has gone bad in 5 years. Or maybe the original white wire developed another bad spot closer to the ignition module? Thanks.
