i am in the process of wiring in a autometer dash and i have converted into a electronic speedo which uses a hall effect sensor at the transmission to send a signal to the new speedo.
now my problem is that i now need to send that signal back out of the speedo and into the vss buffer, but which wire do i connect it to???
correct me if i am wrong, but the original vss on the back of the dash sent out a 16 pulse signal into the vss box, which then converted it into a 2pulse signal for the ecu? is that correct.
please help. i need to get this dash finished.
