Armorall? Never thought of that. I figured it was dirt and moisture.
orall
I have seen that on quite a few car's, turns milky white and hell to get off. Ironic that he would leave it outside for 12 yrs yet Armorall the dash...
SignUp Now!Armorall? Never thought of that. I figured it was dirt and moisture.
orall
The paint jobs on the later third gens were really poor.I have a thing for TTAs. Never had one but I like them. If I didn't like the GN more, I'd have one in a heartbeat. I was really surprised that the paint came off the hood and roof like that. Looks like someone started sanding on it. That car can be saved but it would take a small pile of $$ amd alot of detail work.
What's Good about them other than the run like a bat out of HELL!!This car makes the one I have for sale in the "cars for sale" section TT/A #427 look like a better deal
The car is in the same state only 18 miles away.
Anyone buying one of these cars has the option to see everything on the market and pick the TT/A that they feel would best fit their mechanical, interior, budget and paint capabilities.
Condition is everything.
A well kept driver that was driven regularly and always garaged should be more desirable than a car that was abused and neglected.
Having owned two of these cars since 1999 I know that these cars can have a lot of issues.
Here is a list of issues I have personally run across
1)Paint
2)Spoiler Cracking
3)Seat bolster wear
4)Rear main seal leak and front main seal is a wear item as well but goes un-noticed
5)Intake manifold leak
6)Throttle body seal leak
7)Water in the stock air box
8)Exhaust manifold leaks
9)Ball flange in exhaust rotting out
10)Rubber brake lines locking up the brakes and dragging
11)Power booster vacuum leaking from the new gas breaking down the rubber inside it
12)Short from the red and yellow power wires under the dash causing 14" of wiring to melt
13)Emergency blinker clip inside the steering wheel breaking causing loss of brake lights and emergency blinkers to stop working
14)MAF sensor and coil going bad
15)Stock plastic air intake tube collapsing
16Headlight motors stuck in the up position
17)Window motors and tracks needing to be replaced
18)Rear hatch pull down plastic motor cracking causing the motor to keep running and not closing correctly
19)Radio issues like power not shutting off and other misc. defects
20)TCC switch in transmission sticking (needs an oil cooler)
21)Chrome tail pipe tips hit and scrape
22)Gold wears off all the emblems
23)Intercooler scoop and air dams bottom out and get trashed along with the front aero plastic
24)T-Top seal at side window top is defective from the factory and is prone to breaking and interfering with the closing of the door
25)Door sill breaking from climbing in and out
26)Shocks and struts go flat
27)Some of the lines in the rear window defogger don't work
28)hood vents get warped / distorted from the heat of the turbo
29)Vacuum lines are dry rotted
30)Boost regulator filter disintegrates
31)Boost actuator goes bad
32)Turbo goes bad
33)Cam button wears a hole into the front timing cover
34)Valve springs are flat
35)EGR valve rubber cracks also prone to carbon buildup in the EGR passage
36)Fuel pump sock collapses
37)Glove box door wire breaking / issues
38)T-top shades not staying up
39) Headliner and visors sagging
40)Dash pad cracking
Probably more, that all I could remember at the moment
80's cars suffered from poor quality materials and lack of quality control. I think the only reason I bought one was because I am from that era and since I was a teenager it was something I always wanted.What's Good about them other than the run like a bat out of HELL!!![]()
Any word ?I'd buy it in a hart beat
I'd go 5 grand site un seen
But 9grand is a bit much.
Talk him in to it for me
Sent from my SPH-L710 using TurboBuick Mobile mobile app
