richardv6
- May 11, 2007
What are your opinions. I am using fast 2.0 and wonder if using a volt booster would be ok..would it give false sensor readings or no..what you think.
SignUp Now!I just put my first volt booster (Caspers) on a few months ago and I now get 14.8-15.2 volts at WOT. Before it was 12.2-12.6
I was always told not to use them, but found many of the fast guys run them..Even with alky.
There are threads with John Spina (Caspers) explaining how they work and busting some of the myths associated with the unit.
http://www.casperselectronics.com/store2/product_info.php?products_id=614Is this the CCCI voltage booster you are running?
I've been running volt boosters for almost 20 years. There are measurable differences in running the volt booster. I haven't seen any downsides.
I ran into this too. After talking to other TB owners that run alky, they end up tuning around the added voltage as I have myself. You would also have to consider the amount of people running adjustable regulators in their alternator that run alky too. I really dont see an issue and neither do the people running higher voltage with alky I talked to either.
ive ran it with various systems. My own back in the 90's, smc, and now Julio's. I know I changed the initial on my cars. I don't exactly where they are but they are adjusted. I use a 3.5 bar on one car so the alky isn't injected as much at lower boost levels but still hits the full output. I had one GM 3 bar chit the bed one and was reading lower than actual. When I replaced it all was good again. If you're worried about the alky adjustment I'd leave it alone and use the logs to tune the car.Do you run them with Julios alky system??
And if so what precautions/changes to alky setup or delivery need to be made to prevent using more alky than intended??
Does changing the initial or gain compensate for V/B use and if so what is the general starting point from what Julios kit recommends???
