Volt Booster removal
Justa231
I had a volt booster put on my car many moons ago, and I would like to take it off but have no idea what to do.
Do need any different parts if I take it off? Any suggestions is appreciated.
Nick
If it is a Red Armstrong unit, you will need the original alternator plug that has one wire comes out of it. This wire will need to be connected to the one wire that goes to the VB that comes out of your wiring harness.
Then you will need to plug the vac line at the tee or replace the tee with a straight barb or just replace the rubber vac line to the gas recovery canister. Be sure not to reverse the check valve just before the canister.
Gary :cool:
