Volt booster???
qws2000
I have a volt booster, and when the car is idling the reading on the scan master is bouncing around so much the range being 12.8-13.5...... I also noticed when WOT it never hits any higher then 14.8 Is there anything wrong with the 200 amp alternator or Volt booster
The measurement the scanmaster indicates goes through the ECM and a handful of connections along the way so it tends to be a little low. I would not be concerned with the voltage you are indicating.
