I just received my built engine with 212 roller cam & ported heads with matched intake. Going to be running conservative 20 psi on alky. My engine builder said a volt booster is required to assure fuel system isn't falling short on the big end. It seems a lot of you guys have some negative feedback about these things causing problems. Is the better solution to upgrade to a 200 amp alternator?
Even though this engine is capable of big power, my near stock 2004r trans will be toast if I ran it to its full potential. Therefore, I will not be beating on it at the track, but will be running it hard on the street of course. Just car shows & tire spin in my future until the weak link is addressed. When the time comes to go run it (after trans upgrade) at the track, will the volt booster or 200 amp alternator be necessary? Thanks, Tim
