volt booster
tc86gn
Senior Member
I have acquired a volt booster. No directions. My question is, does it hook up to a vacuum source or boost source?
I don't have that type but sure you T it into a vacuum/boost lines near the alternator.
no vacuum connections on a volt booster....they usually work off tps
don't attempt to hook it up until you have the proper directions
Not to contradict azgn but my volt booster from quad air had to be connected with a vaccum T 1/4 size to the vaccum line that's going to to canister right behind the alternator. And since my volt booster came with the wire with a female connector I just cut my alternator plug (that black one) and put a male connector of the same size. Hope this helps.
Thanks guys that did it. I saw one a long time ago and I wasn't sure if I remembered how it hooked up. You saved me some time.
we are talking a volt booster here?
maybe some versions are triggered off boost/vacuum but everything I have seen recently is tps based...mine certainly is and it is one of Red's
learn something every day:)
Yes it is a voltbooster. I saw one a while back and said the same thing when I saw it hooked up to the vacuum line but had to get some reassurance on the matter from y'all.
