OK, I've been sifting through many, many, many threads on these pieces but nothing came up that is recent so hopefully this won't bug anyone too much.
Scene:
I roll into the throttle in second gear and just after the TPS hits max voltage at around 40-45mph Direct Scan shows 7* of KR at max boost of 25psi at this particular time then nothing more the rest of the run. Ialso have a audible knock detector so I can tell when it's getting knock.
I can't tell what's causing the KR. O2's start around 830 after I floor it (I know this is rich) then drops right down to 810 and I'm still getting KR. At the exact time I get the KR (which lasts about 2 seconds), the alternator goes from 13.3 to 12.5V and stays at this voltage throughout the run....no KR after this point.
Once in high gear the O2's start to fall from 810 down to 770 but I never get any more KR. I'm guessing that the XP fuel pump (hot wired) isn't handling the volume due to the low voltage drop so I'm thinking this could be part of the problem.
I've read soooo many things good/bad about the VB's but again these were old threads (2008-2010).
So what's the take on these VB's from Caspers on a car with alchy:
http://www.casperselectronics.com/store2/product_info.php?products_id=614
If you hate them or they cause too many tuning issues then how do I get my alternator to maintain the voltage? What have you done to solve this issue? There was mention in a thread about changing a diode in the alternator but nothing else was posted on what was needed.
Just to summarize:
I roll into the throttle in second gear around 40-45mph and as the throttle is opened all the way the boost hits 25psi and I get 7* of KR for about 2 seconds. After this 2 seconds - no more KR even through high gear.
I'd really like to get the voltage up where it should be before I really start pushing the boost more.
tia
ks
			Scene:
Just to summarize:
tia
ks
