Voltage at Fuel pump connector
87WE4BOOSTED
I NEED MORE BOOST!!
Hey guys, how much voltage am i supposed to have at the Fuel pump connector? I'm only getting 8v from the center pin. When i palce the battery on the pump it works. When i place the wiring in the mix nothing...Gremlin is killing me.
Center pin isn't supply voltage to the pump
Pin C on the connector is power ... if you have a hotwire kit you should see 14 volts to the pump with car running or ~12.5 - ~13 car off key on ( have someone turn key while your at the back checking voltage)
Thanks for the reply!! I have so much to ask its hard to type it. Wiuld it be possible to talk with you over the phone? If so i canbe reached at 4152871215 You could call now or when its most convienent for you.. If not ill try to type it all out.
Ended up finding the complete fuel system wiring diagram. Thanks
It on gnttype.org under tech...electric/fuel wiring.
