suicide six
- Aug 28, 2005
ok buddy good luck,these things will drive you crazy.Maybe tomorrows your day.
SignUp Now!MIKES86GN said:make sure you check all lead ground wires..make syre that the car is grounded..i went through a ordeal once very frustrating....
85HOT-T said:wierd thing is when i wiggle wires behind the radio the scanmaster shorts out. But i didnt check the light, darn. But those are small gua. wires.
SloGN said:check the wiring that runs down in the console for the shifter lights. thay are known to break into and short out.
85HOT-T said:Ok new info. After messing around for an hour or two I traced it down to a location. The short is running through my trans. I can move the shifter slightly, and see an arc on the trans where the shifter cable attaches. I can hear it grounding through my floor shifter too. So the dilema is WTF is going on here. I have a strap going from the trans to the firewall. I dont know why this is happening. Wierd thing is when my cable started to act up, soon after this electrical problem came along. I wonder if and how they are related. Too wierd, thats all I have to say.
I can't even think where the power would be comming from to be going through my tranny.Oh and FYI, the tcc plug is disconnected too.
SloGN more than likely where the neg cable bolts to the block has come loose.[/QUOTE said:The one thing I dont get is when the car is running and i shift gears it acts up the worse. The engine never stumbles or dies, but everything else loses power. Lights dim, blinkers dont blink, due to not enough amps. When i rev it up everything brightens up???
