VSS sensor on GNX
Dino Calise
DinoGNX
have code 24 is the vehicle speed sensor I pulled dash the green sensor not there also look under hood followed the Speedo cable still nothing does anyone know on GNX where it is ? Thx
It plugs directly into the speedometer housing.
I had to drop the steering column to get the cluster out.
The GNX doesnt use the same green box VSS that the other cars use? Cool
The green box is the buffer the VSS is inside the instrument cluster. It's just a magnetic pick up.
if you want to remove it and it has a mechanical speedometer you'll have to disconnect that in the engine compartment first. I'd suggest removing the dashboard section that surrounds the instrument panel as well so you can see behind it.
First, is this a GNX dash in a real GNX, or a ''GNX''' gauge conversion?
If it's a normal TR with an aftermarket dash, there might not be one right answer.
Yes this is correct... a picture of your dash will help
