Vss
Small green box (buffer) is just to the left of the steering wheel under the dash. I assume your speedo is working. The actual sensor is bolted to the back of the speedo.
Have you tried clearing the ECM of the code first? It should have reset itself if you have been driving it for awhile anyway. The VSS isn't usually a trouble prone part. Code 24 usually sets from reving the engine in neutral or park or because the speedo is broken.
