w-strips
buickman2006
I was wondering has anybody ever dealed with a roof rail seal gm 20737658 which is right side which wont fit car too long on rear part of seal. The left side 20737659 fit perfect made wrong from factory?
Rt W-strip
Buickman, I'm Restoring An 87 Gn, Veh Is Completly Disassembled, On The Rt Quarter,the W-strip Run Mld That Is At The Rear Of The Glass,there Are 2 Sets Of Holes Where Someone(in The Past) Moved The Run Mld,probably To Make The W-strip Fit Better. Wandering If This Is The Same Issue You Have? I'm About A Mo From Paint,i'm Sure I Wil Be Faced Wit Ha Simular Problem As You Are. I Did Purchase All"gm" W-strips.. You May Have To Adjust The Glass With The New W-strips,be Sure To Put Lube On Seal So The Glass Will Not Tear It If Adjustment Is Off.... Good Luck..
roof rail w-strip
No my problem was the right side roof rail w-srip just like i thought was too long at rear part had my gm dealer order me another right side w-strip sure enough compared two and new one just got was shorter went home and installed perfect fit i guess you never know.
