Walbro 430 pump and alky.
Nothing to write home about, 10.70 @122. Should have plenty of pump left.
Not applicable to your new setup though.
I've trapped 127 with a single 450 on e85.
Sent from my E6782 using Tapatalk
What injectors? What duty cycle? What LINEs? What was the setup. Looking to go high 10s in a single 450 and e85
Sent from my SM-N930T using Tapatalk
This was last year in my ls swapped Buick. The car now has dual 450s.
Boost was at 17 PSI and fuel pressure held solid at 60 PSI throughout the pass.
Racetronix 450 sender
1/2" ptfe fuel feed
Aeromotive boost referenced regulator
45 PSI base pressure
ID1000 injectors at 82% duty cycle
11:1 AFR
